It is currently Thu Aug 14, 2025 10:17 pm
PostPosted: Fri Feb 27, 2015 12:12 am
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
Hi All
I have been using Zpoxy for pore filling but have heard of good result from those of you who use West system 105 (resin) and 207 (hardener). So I think I'll give it a try. Same application as Zpoxy or different method? Do you dilute the final coat with alcohol? Any help would be appreciated - Mike
guitarsbygiltzow.com
PostPosted: Fri Feb 27, 2015 9:16 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I switched to it from Zpoxy and find it excellent. I mix it by weight on a gram scale as it is less forgiving on ratio than Zpoxy. It does not put an amber tone to the wood so I find sand through issues are less noticable on recoating. The only thing I find a bit of a drag is it cures slower than Zpoxy, I could sand the Z after 8 to 12 hours and the West needs a full 24 hours. They have the thickener available to add but I use it without, on real large pores I will use an extra application if needed.
Fred
Fred Tellier
These users thanked the author Fred Tellier for the post: giltzow (Fri Feb 27, 2015 12:41 pm)
PostPosted: Fri Feb 27, 2015 9:32 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
No dilution on final is needed.
Doug
These users thanked the author Doug Balzer for the post: giltzow (Fri Feb 27, 2015 12:41 pm)
PostPosted: Fri Feb 27, 2015 9:34 am
+1 to what Fred said.
Also West is used or has been used by at least two pro finishers that I know and they liked it too.
You can thin it as well just like with Z-Poxy "finishing resin" (Z-Poxy also makes epoxy glue but the "finishing resin" is what we like for pore filling from Pacer, the Z-Poxy people).
Either does a great job.
Please also note that epoxies can be sensitizers and we have had at least one bad reaction on this forum to epoxy use for pore filling in the past. Wear protective gloves, ventilate, etc.
These users thanked the author Hesh for the post: giltzow (Fri Feb 27, 2015 12:42 pm)
PostPosted: Fri Feb 27, 2015 1:01 pm
Last Name: Giltzow
City: Boise
State: Idaho
Thanks everyone. Does anyone use the small nap rollers to apply or just the credit card/ auto body spreaders?
PostPosted: Fri Feb 27, 2015 1:57 pm
City: Lawrence
Zip/Postal Code: 66047
I've always used the credit card.
They work great for me.
Never thought about the roller, but I think you want to get as thin a coat as you can so I would follow a roller with a card.
PostPosted: Fri Feb 27, 2015 4:21 pm
Michael if you can find my toot on epoxy pore filling in the toot section I make a big deal out of how epoxy should not be "painted" on but instead "mashed" into the pores with downward pressure from someone else's credit card.... :)
One pro finsher that I know uses foam brushes and that works well for him.
The confusion when using cards is the word "squeegee" (not sure if I spelled that right and my shop computer does not spell check...). So one tends to believe that the card is to remove the excess which is can and is used for too. But it's also used with proper technique to mash the epoxy into the pores.
Coat one generally is to completely wet the pore bottoms so that coat two will stick in the pores. Coat two does the heavy lifting so-to-speak and often it's the case that this is all I need to do, two coats. I've been thickening coat two wiht microballons and that helps too.
PostPosted: Fri Feb 27, 2015 4:26 pm
Just found the toot six pages back and bumped it.... :)
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=20320&start=0
PostPosted: Fri Feb 27, 2015 6:52 pm
Last Name: Giltzow
City: Boise
State: Idaho
Hi Hesh
I have read your toot on epoxy pore filling. I think I have read all your toots. Very much appreciate you sharing excellent advise on so many issues. Thanks - Mike
